Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-06-2007, 02:16 PM
CGood CGood is offline
2002 Pontiac Grand Prix Fan and Display Problem
The blower motor on my 2002 Pontiac Grand Prix GTP and the digital display seem to be connected and both are malfunctioning. This problem isn't consistent. My display is blank and my ac blower will not work except on the five setting (sometimes this setting will not turn on either). Or my display is working and when I turn my ac on the display turns off and the ac won't turn on. At times the display is trying to turn on and just clicks back and forth sounding like a turn signal. Still on and off both work and no problem. I can't find a reason or trigger for the malfunction. Anyone have this problem and any ideas on how to trigger and fix it?
Old 06-07-2007, 06:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2002 Pontiac Grand Prix Fan and Display Problem
Look in the tips and maintenance section at the top of the Grand Prix forums for the ignition switch/harness assembly instructions. This is most likely your issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-08-2007, 11:10 AM
We tried to replace the fan motor transistor but to no avail. Looks like this is a digital or disk problem. Has no one had this sequence before? I don't think the ignition switch is an issue. I saw this problem posted on another forum but no answers there either.
This site has a lot of useful info - I am having issues with my sunroof and will try some suggestions for sealing it. Thanks.
Old 06-23-2007, 05:44 PM
Jase07 Jase07 is offline
Cgood,
I subscribed to this forum to tell you that I am having the EXACT same problem with my wife's 01 GTP. Fuses seem fine. Only works on 5, display in and out, clicking under dash. bangin my head on it right now. If you find out the problem, PLEASE advise.
Old 02-10-2008, 05:13 PM
SsHaDyGt SsHaDyGt is offline
Hello,
I am having the same problem. When I put power to the orange wire leading to the ignition switch, the DIC turns on and the blower works on other settings.
Andy
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Closed Thread
