Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 06-06-2007, 01:26 PM
Bullingju0 Bullingju0 is offline
Rear end swap ?'s
I've got a 69 mustang with a stock 8" rear and i need to swap that sucker out. I was looking at getting a 9", but i heard someone say an 8.8 out of a fox body mustang will work just as well, and they are a lot cheaper. I've looked around and he seems right, but im not sure if there are any fitment issues, or can it just bolt in? I'm pretty sure i would have to lengthen it, I believe the stock 8" on my car is 54" wide, but i haven't measured it. i dont want leaf springs im going with an air bar, and i want 4.11's with a locker. any help is awesome
Old 06-06-2007, 04:55 PM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Re: Rear end swap ?'s
What have you got under the hood. How much are you putting down. Come on we need more info.
http://www.RaceWarz.net/r.php?id=8733 CLICKY CLICKY
Old 06-07-2007, 11:41 AM
I've got a 408w stroked w/ Coast high performance pro-street fighter http://coasthigh.com/Assemblies/Ford/ford_408w.htm
Edelbrock Vic. Jr intake,
demon 850
Tremec tko 600
AFR 205 race heads http://airflowresearch.com/205sbf_rh.php
Full Roller valve train with a Pretty big cam, It's been about a year since i built it and the cam specs have eluded me...Think its like .565 lift with 264* duration and 108 degree lobe centers..
The motor makes about (estimated, never had it on a dyno) 500 horsepower at the crank but i've got plans to go bigger. A rear end that would handle about 600 would be fine for me. I don't see any reason an 8.8 wouldnt, but i want to get some info before i just go out and get one.
Any more info ill be glad to tell
Old 06-08-2007, 02:52 AM
351wStang's Avatar
351wStang 351wStang is offline
A 31 spline 8.8 would work just fine, but personally I'd go to a 33 spline just to play it safe. Strange makes a nice set of 33 spline street axels.
1969 Cougar
357w & TKO - 475hp
Old 06-08-2007, 12:59 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
That is a lot of torque, if you plan on launching that sucker, you need 31s 8.8 or 9 will do fine. I would perfer to have a 9" myself, but that just me
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 06-08-2007, 02:20 PM
351wStang's Avatar
Not sure about the '69 cars but I know it gets hard to set up a fox with a 9". The way they sit screws with the geometry.
1969 Cougar
357w & TKO - 475hp
Old 06-09-2007, 03:02 AM
SkylineUSA's Avatar
That is why I would try to stick with the 9" for the older Stangs. Geometry can be tricky.
Old 06-09-2007, 03:39 PM
Down the road i think a 9" is something i want to go with, but for now i think my budget is better suited for an 8.8. I think i can find one with disc brakes for under $1000, I might have to lengthen/shorten it, im not sure what the length of most 8.8's are
Thanks for all the Input
Old 06-09-2007, 05:53 PM
Also, what's the deal on 4-lugs rears? Can they be converted to 5 lug with new axles, or is it just better to avoid the 4 lugs?
