Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-06-2007, 08:07 AM
92campologrn 92campologrn is offline
camaro problem
I have a '92 camaro 5-speed w/305. While the engine is running, it rev up and down almost stalling. When I press the accelerator, it does not rev like normal (sputtering) and the surging continues like I am not pressing the accelerator. I have to nurse (play w/ clutch and accelerator) the car to get it to moving. When it is moving it has no power and continue to sputter and hesitate. Does this sound like a faulty fuel pump? Please help!!!
Old 06-06-2007, 09:03 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: camaro problem
Sounds like it could be a low pressure or volume issue. Installing a gauge and check will confirm.
BTW- TPI or TBI?
Old 06-06-2007, 10:07 AM
Re: camaro problem
It's a throttle body (TBI). If the volume and pressure is determine to be low - fuel pump problem or what?
Old 06-06-2007, 10:43 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: camaro problem
Sounds like fuel pump to me. Change the filter just to make sure its not clogged before you go and spend the money on a pump.
Good Luck man
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 06-06-2007, 11:35 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: camaro problem
hell yeah, i was gonna say check that damn fuel filter and work your way up....
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 06-06-2007, 11:41 AM
Re: camaro problem
What is a throttle position sensor? Someone suggested that might have failed.
Old 06-06-2007, 11:54 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: camaro problem
sounds like ignition to me
Old 06-06-2007, 12:46 PM
Re: camaro problem
Genopsyde- You said ignition problems. What do you suggest I do?
Old 06-06-2007, 07:34 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: camaro problem
my car did the same when I bought it. (mine was really a piece of crap when i bought it, so kinda apples and oranges here)
I replaced the ECU and fuel pump + filter. Can't remember 100%, but I think that particular problem went away after the new ECU. (It already had a new TPS).
You problem could be a lot of things (only a few of which are cheap replacement parts). Start with the simple stuff and try to narrow it down.
(in order of cost effectiveness and simplicity)
check timing
reset computer (disconnect battery for 5 min)
replace fuel filter
have muffler shop check for clogged cat converter
get fuel pressure gauge (for fuel injection), ensure proper reading
(acceptable pressure for TBI is....? 25-30psi? someone clarify that)
replace TPS
get a diag check done on the computer.
...by now you should know the source of the problem...or have a good idea... and know what to spend the big bucks on.
have you tried letting the car reach a warm temperature first?
mine only ran like that when it was cold... which helped us find a bad computer and failing O2 sensor.
EDIT: Oh, and the TPS, throttle position sensor, tells the computer when you press on the gas... so it will add more fuel to the engine. if bad senor, it doesnt add enough fuel = engine wanting to cut out.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-06-2007, 09:41 PM
Re: camaro problem
Thanks guys for all the input. These suggestion will definitely get me started.
I anyone has anymore input, I am listening.
Old 06-06-2007, 10:17 PM
Genopsyde's Avatar
The President
Re: camaro problem
sounds like a misfire, possible multiple misses, you'd need an hei spark tester to see tho. you'd hafta pull the fuel pump fuse which is by the battery on the right side fenderwall, then connect the tester to each plug wire one by one and crank it over and watch for spark, also use it on the wire for the coil to see if the spark from the coil is strong enuff.
