Old 06-06-2007, 08:02 AM
laxman21's Avatar
laxman21 laxman21 is offline
A/C question MT2500
Anyone have the shop manual that has the pressure reading for a 99 blazer? Low and high side.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 06-06-2007, 09:16 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: A/C question MT2500
The pressure readings will vary.
Outside tempt and air flowing threw the condenser and rad has a big affect on the high side readings.
Good low side will range from 28 to 35 lbs while the compressor is running.
Good high side readings will range from under 200 to 350 lbs depending on tempt and air flow threw condenser.
You need to take readings at idle and at 2000 rpm with compressor running.
The low side pressure will run close to vent output tempt.
For ever lb of low side pressure = 1 degree evaporator tempt.
30 lbs low side should put 30 degrees out put from evaporator.
And give you around 35-40 degrees vent tempt.
MT
Old 06-06-2007, 11:16 AM
laxman21's Avatar
HMMMM.
at idle
78* outside
Compressor would kick on at 50LBS low and 105 high
Shut off at 24 and 145 high
vent temp at 54
What about a suburban?
45 low and 200 high the whole time...never shut off
52* at vent
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 06-06-2007, 11:55 AM
MT-2500's Avatar
AF - Advisor
On the Blazer if it is cycling on and off very much You are low on R-134a.
And vent tempt is a little high.
I would pump it down and run a Vacuum on it and recharge with the set charge.
Also the low side turn off is boder line low with a 24 lb kick off .
You need to have the turn off closer to 28-30 lbs.
The evaporaor will freeze up at 24-25 lbs.
On the suburban you may have expansion valve/orfice tube problems.
Does it have rear air?
For good cold air you need to keep the low side around 28-30 lbs.
MT.
MT
Old 06-06-2007, 07:34 PM
laxman21's Avatar
MT.
THe burb has rear air.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 06-06-2007, 07:38 PM
MT-2500's Avatar
AF - Advisor
If you can find a place to do it pinch off a hose on rear air and see if pressure gets better.
If so the expansion valve on rear unit is bad.
MT
MT
