Old 06-06-2007, 02:49 AM
a_alyte a_alyte is offline
Question Temp guage concern & headlight question
I have a '00 GT & my temp guage rises just above 210 when in city traffic. The temp does fall back to 200 after a while. The manual states that 200 is the normal temp. Is this a potential problem? I recently installed a new thermostat along with coolant flush from valvoline.
Also, when the car is running at night, the headlights stay on even though the switch is in the off position. Is this part of the DRL & if so, would disabling the DRL allow me to turn the headlights off when the car is running at night?
Thanks
Old 06-06-2007, 05:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Temp guage concern & headlight question
I would say that your temp fluctuation is no concern. The 97-03 GP's have auto-on headlights, which is controlled by the ambient light sensor sticking out of the center of the dash. I personally like the feature, although it sucks at the drive-in theatre if you want to start the car for a few to cool the interior off or out the windows up/down.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-06-2007, 11:56 AM
Thanks for the reply.
As for the headlights, I have a Jeep that also has the auto-on feature but these can be turned off with a flip of the switch. I'll just have to adjust to the Pontiac setup.
Old 06-06-2007, 11:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Man, i have completly disabled my DRL's and automatic headlights in my 2000 GTP. I dont mind drl's, but hate automatic headlights. If you feel like going that rout, PM me and i'll tell you how to. Its actually quite easy and only costs a couple bucks at radio shack and about a half hours time.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-07-2007, 03:45 PM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
I disabled my headlights by pulling a fuse . Now I can run my foglights with my parking lights only. I like it that way. Kinda makes me feel ...
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 06-09-2007, 12:26 AM
tblake's Avatar
In God We Trust
how did you do that? What fuse did you pull? When i trieed that approach i got some sort of relay clicking sound constantly constantly when the ignition was on.
Old 06-10-2007, 08:53 AM
tblake, I've never used the PM function & can't seem to find it. Can you PM me with info on disabling the auto headlights?
Old 06-10-2007, 02:14 PM
medicmandan medicmandan is offline
I have the same temp problem. My cooling fans are not coming on when the temp rises.
Old 06-11-2007, 12:06 PM
Squirlw/SE Squirlw/SE is offline
Cool Re: Temp guage concern & headlight question
i have an '00 grand prix, 3.1, se, automatic. i have the auto option on my headlights as well and i have found that if you want to run the engine without the headlights on, like at the drive-in, just set your emergency (parking) brake and the lights go out.
Old 06-12-2007, 10:29 AM
Firstymer Firstymer is offline
I notice my 2000 Pontiac Grand Prix SE passenger headlight is deam while the driver's side headlights is brighter. I took it to Autozone and they told me it could be that its going dead. So I decided to buy a new bulb. Can someone help?
Old 06-12-2007, 12:39 PM
Did you replace the bulb? Is the problem still there?
Old 06-15-2007, 08:15 PM
dpenton dpenton is offline
When you want your lights to be off when parked.Shut off your car, set the parking brake and volia..no lights.
Old 06-18-2007, 01:57 PM
Yes, I replaced the buld and I believe it work. I notice 2 nights ago both headlights seem to give off the same amount of lighting.
Old 06-18-2007, 02:00 PM
I notice my temp guage is not working. For example, if the car is on-enging, but the guage is not moving...it always stays at the bottom. What seems to be wrong? How can I tell if my engine is runing hot or need coolent if the gauge is not working?
