Old 06-05-2007, 10:29 PM
jshort74 jshort74 is offline
Trany Problems 95' Windstar
I just started experiencing a dis-heartening problem with my '95 windstar. It has 104,000 miles and a 3.8L engine. I experienced what I think is slipping when accelerating from a stop. The engine rpm's go up but the van doesn't go as you would expect. Also, at idle it will no longer hold the car on even a small hill. This problem is intermiten right now. I changed the oil, rotated the tires, and checked the brakes the day before it started happening. At that time I also checked the transmission fluid level and found it was full and clean looking in the dipstick. I checked again today and the level hasn't changed. I had the transmission rebuilt about 3 years ago. the van had about 80,000 miles on it at the time. A mechanic friend of mine (doesn't work on tranny's) checked for codes today and found code P1785 Trans fault 1st and 2nd. I searched here and the net for a little more info and found this more detailed description: "Transmission Mechanical Failure 1st & 2nd." Can anyone explain to me what is happening and why? Thank you for your help!
Old 06-10-2007, 12:04 AM
Re: Trany Problems 95' Windstar
Anyone?
Old 06-10-2007, 05:34 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
My 95 is also doing this. My 93 Taurus also did it. As I understand the problem, there is an alum piston in the tranny that cracks over time. Because of the crack in the piston, the trannie doesn't respod I like it should under stress. I've been driving my 95 like this for quite a while. I just take it easy until it shifts out of 1st. Also, If you go to pass don't put the pedel to the metal. The engine will just rev. I believe there is a TSB about keeping the trannie fluid about a 1/2 qt. above the full line.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 06-10-2007, 10:51 PM
Does anyone know anything about this TSB (Keep tranny fluid 1/2 quart above full line)? I would like to know the number. Also, It is the cylinder piston that cracks? Well, I guess that's better than the cylinder bore being cracked!
Old 06-19-2007, 01:55 PM
Does anyone know this number?
Old 06-19-2007, 06:34 PM
DRW1000 DRW1000 is offline
TSB 99-18-4
It actually states to keep the level at the top of the hash marks on the dipstick. It is to correct harsh shifting from 3-2 or when accelerating out of a turn. The cause of the harsh shift is due to air getting into the filter pick up from too low of a fluid level.
I am not sure if this applies to your issue but it is an easy thing to check and correct.
Old 06-23-2007, 07:55 AM
The problem has now gone away or is sleeping. I hate sleeping problems!
Old 06-23-2007, 06:00 PM
BLADv4 BLADv4 is offline
Hi, I have a windstar 97 lx 101,000 3.8l and I have the same problem that seems to be a transmission neutralization when you almost stop (some times happen, not ever). I've noticed that this only happens when I use D (overdrive on/off happens the same). if I drive in 1st, 2nd or reverse the problem never appears.
The transmission gets neutralized for a few seconds, some times shorter and some times longer, even if I push the accelerator. This never happens when going, only while stopping.
i have mercon dexron III ATF right now and a ford dealer says it should be mercon V but I think this is not the problem.
Any body can help?
Thanks in advance.
