Hard shifting when a/c is on
I have a 03 chev impala and i have been noticing that after the engine is warmed up and the a/c is on the vech shifts real hard in the first 2 gears and a slight in the3rd gear too. It seems to run fine when a/c is off in the morning when I go to work. On my way home it starts off fine then (warms up) while in traffic, that is where my problem starts. I just did a tranny flush with new filter and the car has about 92xxx miles on it. I also noticed when it is cold if I step on the gas hard, the the there is a delay when the tranny kicks in. The car jumps and then goes with on problems at all until it gets warm. Any advice or help would be very good to me because I have no clue as to what it might be.
Re: Hard shifting when a/c is on
Take it to a trans shop and get it scanned for a DTC P1811. They do shift firmer with the AC on because the PCM commands higher line pressure.
I will do that thanks for the info Troy1
where do you get a transmission cooler? is it hard to install? |
