Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-05-2007, 10:16 PM
ksuwildcatz ksuwildcatz is offline
no running lights on trailer
I have turn and signal lights but no running lights on my trailer. I have a testing adapter and it showed no running lights. The running lights on my 02 explorer work just fine. Any ideas????
Old 06-05-2007, 11:19 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: no running lights on trailer
It appears that the 2002 Explorer trailer wiring adapater does not include running lights, just turn/brake, and backup lamps.
Pin 1 (Yellow wire) = Turn lamps, feed, left rear
Pin 2 (White wire) = Trailer tow connector, ground
Pin 3 (Dark blue) = Electric trailer brakes
Pin 4 (Dard green) = Turn lamps, feed, right rear
Pin 5 (Orange) = Voltage in Run (overload protected)
Pin 6 (Brown/white) = Trailer tow relay, switched output
Pin 7 (Black/light green) = Trailer tow connector, Reversing lamps
-Rod
Old 06-06-2007, 04:07 PM
-Rod
I called the ford dealership this morning and they said that it does have running lights. Who is right. I have a feeling the dealership was just blowing me off.
Old 06-06-2007, 08:18 PM
shorod's Avatar
SHO No Mo
The information I posted is from the factory service manual. I suspect the factory is more correct than the dealer.
However, if you want to verify it, get our your multimeter or test light and probe the connector.
-Rod
Old 06-07-2007, 07:49 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check fuse 27 in the underhood fuse panel. There is a trailer parking lamp relay installed in the module. This fuse feeds the relay.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-07-2007, 09:46 AM
denisb denisb is offline
Daytime running lights are only your headlights, not your park lights. So since a trailer only uses markers and brakes, that would be why you don't have a connection for daytime running. I'm guessing the dealership thought you meant your park lights when they said you should have a connection for daytime running.
Denis
Old 06-07-2007, 11:55 PM
shorod's Avatar
SHO No Mo
Way2old's diagram matches the wiring diagram in my service manual. From the diagram, it would appear the, assuming you have the class III/IV connector, pin 6 should be the parking/trailer running lights. If you have the Class II connector, the parking/trailer running lights would be pin 2.
I overlooked the wiring diagram and went straight to the connector pinout.
Denisb's does post did get me thinking about another question though, you are checking your parking/trailer running lights with the vehicle parking or headlights on, right?
-Rod
Old 06-08-2007, 08:38 PM
Sorry, I should have looked up your location. Being from Canada I assumed you were talking about daytime running lights (which is just your headlights).
Old 06-08-2007, 10:33 PM
fuse 27 was blown. Thank you Aaron
