Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-05-2007, 01:50 PM
Scott Dog Scott Dog is offline
1992 Ranger Knocking, and much more
i have a 1992 Ranger with a 2.9L V-6, it has a lot of problems, the check engine light randomly comes on and the truck sometimes idles rough at stoplights. Another problem i have been experiencing is that my truck smells like it is hot or burning oil, but there is no smoke from the exhaust or motor, and the temp. gauge reads that the motor is running about normal, when i check the oil and antifreeze they are always both low, but the motor doesn't seem to be leaking any fluids, I am Stumped, on top of all that, my motor has now started to knock a little bit, Please help me!!
Old 06-10-2007, 09:09 PM
papi62596's Avatar
papi62596 papi62596 is offline
Send a message via AIM to papi62596 Send a message via Yahoo to papi62596
Re: 1992 Ranger Knocking, and much more
Sounds like you might have a blown head gasket. You might want to check your oil and see if it is milky at all. Also check inside of your radiator and see if you have any oil in it.
Old 06-11-2007, 12:54 AM
DonSor DonSor is offline
Good possibility you have a blown gasket. Notice any white smoke out of the tailpipe? Losing oil and the smell of it not only could be the result of oil getting into your cooling system but also leaking out out of the hot block. In any case it sounds like you'll need a lot of expensive work. What's your mileage?
Old 06-12-2007, 06:02 PM
it has 167,000 miles, and i do not notice any smoke coming from the exhaust but there is sometimes smoke coming from the passenger side of the motor
Old 06-12-2007, 08:22 PM
Losing oil. Losing water. Smoke coming out of the engine. Narrowed down to a blown gasket. Looks like the gasket section blown is between the cylinder/s and external to the block and/or water jacket and external to the block as opposed to between cylinders and the water jacket. No matter how you look at it it will take a major an expensive repair job. At 167K miles I don't know if it's worth the repair.
Old 06-14-2007, 01:49 PM
i think i'll just run it until it blows up, it's a piece of junk anyways, but thanks for all the help!!
Old 06-20-2007, 09:10 PM
bratt bratt is offline
id look for leaks on the ground. if you dont find any, just blow that sucka up and then pop in another working one.
if you find a leak fix it!
