Old 06-05-2007, 12:17 PM
hatchie hatchie is offline
B16A into 91 civic axle question
hey guys, new to the forums, and yes i promise i used the search and couldnt find what i was looking for.
i have a 91 hatchback. in it is a dohc b16a with a LS tranny. it all of a sudden started wobbling as if the cv joints went bad. got it home and swaped out the axles with what i think are the exact same that i had put in when i had the swap done. the wobble went away a little bit, but its still there when i turn. right now, my car is undrivable =(
it would be appreciated if i could get some advice from ppl who are familiar with this type of swap (very common i suppose). what axles do i use for each side? what i ask for when i go to auto zone is axles for a 94 integra 1.8 without ABS, but i dont believe those are the right ones. any detailed info would help a ton, kragen/autozone/napa axle part numbers would be golden.
thx and much love
Old 06-05-2007, 05:24 PM
Hybrid1990crx's Avatar
Re: B16A into 91 civic axle question
90-91 integra axles is what I used.
Old 06-05-2007, 05:40 PM
hey, thx for the response. kragen/auto zone is gonna ask me what kinda integra, what should i respond with? they ask year make model and engine size. if i could get that bit of info, i can head on down there and give it a shot
thx again
edit: also, will that fit with an LS tranny
Old 06-05-2007, 08:47 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
thx again
yes 90-93 integra axles mate....
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 06-06-2007, 12:21 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
thx again
90-91 teg non-abs axles from an ls,gs, rs whatever, just make sure there from a non-abs car.
The axles will work with any b-series tranny you use.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 06-06-2007, 12:38 AM
thank you for the responses, ill be sure to try this out this weekend when i have time.
peace out
Old 07-06-2007, 03:14 AM
ok just got done putting in the new axles from a 91 integra non abs. put in the pass side first, turned the disc, and no wobble. so far so good. put in the driver side, turned the disc, and there was a slight wobble. it was about 10% of the wobble it used to be, so 90% gone.
drove the car around the block, and it only wobbles slightly when i turn hard right. ive gone through 3 sets of axles. all my motor mounts are on right, my tires were mounted on tight, and had proper air pressure, i dont know what else it could be.
it all started one day while i was driving down the freeway. my car started wobbling while driving out of nowhere. heres the wierd part. no matter what speed i was going, my car would only wobble while i was giving gas. i could be going 90, and it would only wobble while accelerating, but if i were to idle at 90, no wobble. get home thinking it was CV joints, replaced axles and wobble still there. here i am now 3 sets of axles later and im out of options.
please help, currently im driving a 1970 monte carlo 128 miles to work, and im basically working for gas money atm >< need my hatch running again
thanks
Old 07-06-2007, 04:41 PM
viper-blue's Avatar
viper-blue viper-blue is offline
did you get a wheel alignment done after you changed out the spindles for your swap? Are you sure your pushing the axle into the trans all the way so the circlip is engaging nice and tight? After that many axles there must be something going on there. Aside from a really bad wheel alignment issue, the only thing I could see causing your problem are misaligned mounts (or wrong ones altogether), the circlip isn't locking the axle into the tranny, or your axle nut isn't on tight enough.
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 07-06-2007, 06:00 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
bad bearing and its not the axles at all? But thta would prolly make a god-aweful noise..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-06-2007, 07:18 PM
ironman85's Avatar
ironman85 ironman85 is offline
Send a message via Skype™ to ironman85
what i ask for when i go to auto zone is axles.......
thers your first problem. i used to work at autozone and i like them. but their CVs aren't teh best out there. try carquest/napa. still a lifetime warrenty but better fitment/quality.
'91 Honda Accord: 2" drop, 5 spoke bronze 17's
CURRENT PROJECT: 89 DX hatch. soon to come --> full suspension upgrades, b20 swap and boost
Old 07-06-2007, 08:30 PM
viper-blue's Avatar
thats what I thought when he mentioned the wobble. A cv usually gets the wobble from lack of grease. I had mine go today actually, lol..funny I was reading through past posts trying to figure out if I could take the inner joint of my remaned right axle and use it on the left..I did and it fit, I had the same symptoms..horrible vibration off the line and particularly at high speeds when I was on the throttle. There is just no way that all the axles that you've put on your car are bad before you drive them though..gotta explain the wobble your getting when you turn the tire. Is it a wobble your seeing in the axle? The only way I could see that is if its binding somehow, and again..in all three axles? Have you smoked any curbs and maybe bent an arm on that side?
Old 07-07-2007, 01:06 AM
FrodoGT's Avatar
Sounds even more like a shot bearing, would really be noticeable when you put some kind of torque on the wheel, either forward..backwards, or rounding corners. If the actual axle is wobbling in the hub.
Current project:
Rio Red 91 hatch.
Old 07-07-2007, 10:30 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
yeah i agree with the wheel bearing idea..i had to get mine redone after puttin in my b16. i was drivin back up to columbus one night and as i was turning my wheels wobbled and it felt like i wasnt in contol. probly couldve lost it right into the median if i didnt slow down and take side roads
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
