brake lights
97 blazer 4+4 the rear brake lights work but the center bar brake light is out is it a seperate fuse or does the whole thing just burn out??
Re: brake lights
Always check all fuses.
Does it have 12 volt brake light power to it and good ground?
Re: brake lights
Check what MT said to check and then if that is not the issue you are looking at around $100 part and dealer only item or so I was told 3 years ago. You will not pass inspection without it working.
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
