Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 06-05-2007, 08:42 AM
frolicgfx frolicgfx is offline
1994 Ram 250, adjust air/fuel on carb
My van failed emissions due to high CO, assuming that it's burning rich, I went to adjust the air to fuel mixture on the carburetor and I can't even find the adjustment screws to do so. Normally they are on the front of the carb right? Seems a dumb place to put them on a ram van, as it would make them impossible to reach, but even still, I have looked through with a flash light and don't see them, and I have removed the engine cover and air filter and don't see them on any other side either.
Anyone know how to adjust the fuel-to-air on this thing?
Old 06-05-2007, 09:22 AM
alloro alloro is offline
Re: 1994 Ram 250, adjust air/fuel on carb
They're sealed and not adjustable.
Old 06-05-2007, 09:48 AM
Ok, so is there any way to reduce the CO output other than this?
Old 06-05-2007, 10:56 AM
High CO= Rich condition, CO is from partially burned fuel.
Common Causes:
-High fuel pressure
-Leaky injectors
-Faulty temp. sensor
-Thermostat stuck open
-Clogged air filter
-Sticking choke
-High float level
-Leaking accelerator pump or power valve
-Charcoal canister full, fuel to topped off, faulty purge solenoid
-Fuel in the crankcase
