Old 06-04-2007, 09:11 PM
juanitarain juanitarain is offline
98 escort jerking
i have a 98 escort that i just bought used, and it's one problem after the other!! I just recently had the transmission rebuilt, replaced the distributor, front brakeing system, spark plug wires and spark plugs. Now there seems to be a new problem. My check engine light has come on (again) and now blinks when im accelerating. My engine's giving a little kick up hill, and it feels like its struggling. We've had a ton of rain recently, so i don't know if that matters. I literally replaced my spark plugs and wires two weeks ago, it couldn't be that again, could it?
Old 06-04-2007, 11:38 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 98 escort jerking
Get the code from the check engine light. That should tell you exactly what your problem is... or at least where to start.
If you didn't set the gap on your plugs, then yes, that could potentially be a problem.
Hard to say anything with the information given. The code will help a lot.
Old 06-05-2007, 04:18 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
I agree with moose. Could be a host of other problems. After all those mods you talk about was the computer ever reset? At least start by checking the plugs and gap even though you just put them in. You could have a cracked ceramic or pentirated/grounded plug wire. Check all that and get back to us
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 06-05-2007, 08:10 PM
Davescort97 Davescort97 is offline
Escort guy
Welcome to Automotive Forums! Check the boots of the wires and make sure they are all the way onto the plugs. If you had someone do the work for you go back and tell them (in a nice way) the kind of problems you are having and mention the erratic behavior going up a hill. If the plug wires are loose on the plugs or on the coil packs it could cause hesitation up a hill. If you feel like it take it to Auto Zone and have them "pull the codes" on the Check Engine Light. They will be able to tell you why the light is blinking and will be able to tell you what needs to be fixed. They won't charge you for this service. They hope you'll buy the parts from them. It's better to go some time when they aren't too busy. If you know why the light is coming on you can better make a decision as to whether or not the current problem is from some work you had done. Thanks for coming to our forum. Let us know how things have progressed for you. Just log on again and let us know how things are going. Moose and
Chevy are right on. Dave
Old 06-06-2007, 06:24 AM
chevyn0va1's Avatar
Originally Posted by Davescort97
Welcome to Automotive Forums! Check the boots of the wires and make sure they are all the way onto the plugs. If you had someone do the work for you go back and tell them (in a nice way) the kind of problems you are having and mention the erratic behavior going up a hill. Dave
You know if the plug wires were pulled of for any reason (like to reset/ reattach) and the boot is not pulled the right way you can pull the connector right off the end of the wire (while the connector is in the boot and can't be seen). That's why even though you "just did it" you'd might want to check these out anyhow.
I had that happen once and I tried to repair it but still didn't work well.
