Go Back   Automotive Forums Car Chat > Buick > Regal
Old 06-04-2007, 08:20 PM
xfarmer xfarmer is offline
Red face Water Pump Gasket
I am going to be attempting to replace the water pump in my daughters '94 Regal 3.8L. It doesn't look like it will be too hard to do, but I am not much of a mechanic. Does the new gasket need to have Permamtex sealant? If so, does it go on both sides of the gasket or only one side?
Thanks in advance for any answers or suggestions that will make this project easier for me.
Old 06-05-2007, 04:51 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Water Pump Gasket
The gasket shouldn't require any sealant if it is new. Just make sure to remove all the old gasket material from the mounting surfaces.
Old 06-25-2007, 11:21 AM
raybuick raybuick is offline
Its always good to put a little sealer on both sides of the gasket. I did it and havent had any probs or leaks in years. Its actually a easy job -remove coolant overflow out of the way- drain some antifreeze if applicable- with proper socket wrench, untension pulley off water pump- scrape of old gasket after unbolting pump........good luck
