Old 06-04-2007, 04:42 PM
maximusnukeage maximusnukeage is offline
Question I need advice
When getting new speakers for a car, is it a good idea to get better speakers for the front, and worse speakers for the back. I ask because I'm on a budget and I want component speakers up front and regular 2-ways in the back, with the subwoofer.
This is the 'bass system' I'm thinking of getting:
http://www.crutchfield.com/S-008Z4ui...03XT&s=0&cc=01
This is the component speaker system for the front:
http://www.crutchfield.com/S-008Z4ui...5250&s=0&cc=01
and I'm trying to decide between these:
http://www.crutchfield.com/S-008Z4ui...0&I=130TSA6871
and these:
http://www.crutchfield.com/S-008Z4ui...00&I=1086812CF
for the back.
Any Comments or advice would be greatly appreciated. I'm totally new to the whole car audio thing.
Old 06-04-2007, 04:49 PM
Re: I need advice
The car is a 2000 mercury sable wagon, by the way.
Old 06-04-2007, 04:50 PM
alphalanos alphalanos is offline
Re: I need advice
You can forget about the rear speakers. If your front stage is set up properly you wont need rear. The polks should be decent enough, but you may want to get something better like RE, or CDT. I assume you already have a head unit with at least two sets of pre-outs for your front stage and subs. Youll need a decent amp to power your components. For the subs I would look at a high quality 10 or 12 which you can build a box for yourself for cheap. You will soon find that retail store equipment is hardly average. Check the Sticky in this forum for a list of recommended brands. you cant go wrong buying from companies on the 'highly recommended' list. Make sure you research ALOT before buying, because if you settle for cheap stuff you will regret it.
96 EJ6. Future home of boosted B18C1.
Old 06-04-2007, 05:10 PM
Re: I need advice
I only have a few hundered dollars to spend. is that really enough for amps for all of my speakers? I'm uncertian about the specs of my head unit. I'd prefer to get a pre-enclosed subwoofer because I dont have any wood working skills/equipment. If I have amps for my front speakers where will I put them? I dont have extra space up front. Also, can you recommend where I should go for installation? Since I dont have any tools/skills with electrical systems or cars.
Old 06-04-2007, 07:20 PM
Re: I need advice
Circuit City/ Best Buy can do it, but sometimes they do a crappy job. Components really need to be amped, but you will definetly see an improvement even if you dont. As long as you dont crank it too much they should be fine. The sub will work, but might have build quality problems.
Old 06-04-2007, 11:16 PM
Re: I need advice
on a budget of $500, what parts would you personally sugjest?
Old 06-04-2007, 11:49 PM
Re: I need advice
If it was me, I would get a decent front amp such as Hifonics, and the best set of components I could find. Maybe something like:
http://www.woofersetc.com/index.cfm?...roduct_ID=1190
and amp:
http://www.woofersetc.com/index.cfm?...roduct_ID=4201
Then just forget the sub for awhile. Then once you have mroe money, pick up maybe a 10" sub in a ported box. You dont need much to get decent low end in a wagon/hatch.
Its really worth it to make sure you get the best stuff you can, because you can always take it out and put it in your next car.
Old 06-05-2007, 12:03 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: I need advice
Your best bet to get a decent setup that will last a long time and wont sound like crap is to check on ebay for prices sometimes half of what others retail them for. Instead of trying to get the best try to stick to mainstream brands that have been around and arent trying to sell a chromed peice of shit. Check out infinity kappa series subs, Polk makes some nice mid level subs for a good price, you can get a single sub and a 4 channel amp so you can run the sub on 2 channels bridged and the speakers on the other 2. My amp was 175 shipped and its built like a tank. Those components are actually pretty good, you can get some b grade CDT's on ebay for about 100, also check into mb quart, infinity, and alpine. Same with subs. Keep in mind that installing it your self will save you roughly 100-200. There are plenty of step by step instructions on line that make it easy. All you need is basic hand tools, screw drivers, adjustable wrench and electrical tape and vice grips. I did an install in an accord with nothing but a screw driver and a pair of vice grips in my front yard.
Now for amps, check out profile for good priced amps that will work good for a budget, hifonics are good stay away from brands like pyramid, pyle, dual, jensen, and sony. Visonik makes decent subs but im talking on a flea market level. If i can get some time tomorrow i can search on ebay and other places to find you all the components and prices to try and keep it under 500.
Also keep in mind the last sub bought which is an RE SX 18" was 300 and i got a hell of a deal on it. My first amp was 175 and my second one was 225, the deck was 200, and my comps where 170. So far in wiring not including my rcas was about 80, and the rcas are about 30 a set and i need 3 sets. I still have more work to do and i need sound deadener and other things. But my first setup was around 750 for everything, and also remember that car audio is addictive.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 06-05-2007, 02:04 AM
Re: I need advice
I dont really know if I'd beable to tell the difference between the $130 component speakers and the $370 component speakers. On the Sub I'm thinking of getting the signal responce and all of that seem to be good. what other ways are their of checking to see if a product is good?
Old 06-05-2007, 06:30 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: I need advice
if you chrome a piece of crap, it's still ....... a piece of crap
Old 06-05-2007, 07:44 PM
PlayStation3 PlayStation3 is offline
Re: I need advice
Originally Posted by PaulD
if you chrome a piece of crap, it's still ....... a piece of crap that is now shiney
corrected for the better
Old 06-05-2007, 09:14 PM
Re: I need advice
Beleive it or not most car audio is actually "get what you pay for" In retail cost anyway. So the difference between $130 and $400 comp speakers is going to be huge. Quality, durability, performance. Everything. A good high quality set of speakers will last a very long time when used properly. So its a good investment to get good stuff. I understand you want to save money, but if your going to do it, do it right.
Old 06-05-2007, 11:00 PM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
Re: I need advice
about 99.999% of speakers on the market can do an kick-ass job doing what all speakers do at lower levels....
about 50% of all speakers on the market can do a respectable enough job at higher levels for relatively short durations without damage....
but it's that top percentage that everyone calls the good sh?t...that's the stuff that you can hit with a bazooka, (pardon the pun), all day,
everyday and it will keep on pounding loud and hard for years and years. If you decide on the cheaper stuff you're sooner or later going to
have to deal with it's inevtible failure, or live with the compromises...three burnt-up $100 speakers in three years is not equal to the one $300
speaker you can pound forever
SELLING THE HONDA...
Old 06-05-2007, 11:46 PM
Re: I need advice
So, do you think im going to need to replace my head unit? also, do you think the component speakers in the front need to be amped?
Old 06-06-2007, 12:35 AM
Re: I need advice
Ive burnt subs but with all the crap ive done to a set of speakers ive never been able to blow them. Amped or powered off the HU. You have to think even a set of lightning audio speakers powered off an amp will sound better than a set of stock speakers in a car that has a mojority of its attention drawn to the sub. Out of past experiences and the fact that you are not going for a competition grade setup you will be fine with a set of $130 comps.
Now like the other guys i dont believe in getting what you can afford to sacrifice more money later to get what you really want. But alot of people wont know major difference in a set of speakers. I would rather save up and get what i know will be the best that i want and need. But sometimes something like the polk db's might be more than what you need. And yes you want to amp them if at all possible. Remember one thing car audio is a majority personal preference, what sounds good to you might sound like crap to someone else or amazing, its all in what you need and what you want. I know spending 300 on a set of speakers seems mind blowing but like i said the ones you want might be more than enough for you.
And like i said earlier check ebay prices will be cheaper, everyone always says what about the warranty or what about this. Ive never blown and amp and anything that i have screwed up has been way out of warranty and if you spend say 75 on the same set that cost 130 thats more money in your pocket for other stuff.
Also on the sub you cant look at one feature and say wow this is a really good sub, in order for a sub to sound good and provide the nice lows all of the TS specs must work together, the sub is only half the equation, the enclosure and amp make up a majority of how a sub sounds. And like someone said you get what you pay for, but remember not everyone can afford a ferrari or a lexus. But in the same aspect you dont want something will last a week and sounds like ass, so dont get a hyundai or daewoo.
Cardomain
