Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-04-2007, 03:20 PM
spoolinmonkey spoolinmonkey is offline
Svt Engine Rebuild/ Replacement???
My engine is kinda messed i think it makes a rattle/grind noise this stays consistant with the rpm somtimes...its not plastic or anything...im just curious
how much would it be to replace my svt engine or better yet just rebuild it????
thanx guys
Old 06-05-2007, 10:34 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Svt Engine Rebuild/ Replacement???
If its in the bottom end, you would be better picking up a 3.0L since they are cheaper than an svt 2.5L block. Theres no point in rebuilding when that is more expensive than just throwing a used motor in there. Used 3.0Ls start from about $400.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-05-2007, 02:29 PM
...so are the 3.0 fairly easy to find, aswell as to swap in??? i wouldnt be doing the work myself.....
Old 06-05-2007, 03:16 PM
Considering Ford currently or did put the motor in the Taurus/Sable/Escape/Lincoln LS/Jaguar/X-type, etc its readily available. Pick up a motor from the Taurus, Sable, Escape for the cheapest. Yes, its fairly easy to do. Its done so much, we have a 3.0L branch over on contour.org with how-to's, etc.
"The CEG Nazi"
www.contour.org
