Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-04-2007, 12:04 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Valves, not seating?
I pulled the head on the Talon Sat.
Everything went smoothly...
All the timing marks were aligned before I took the heads off (no interferance). The car ran out fine before the heads were removed (even fixed the damn idle [gaskets]).
I took the heads and laid them on my porch, aligned the marks, and looked closely. Something just wasn't right. I have 4 valves (intake, cylinders 2&3) that aren't seating. They stick out enough that there has to be some leaking. I'm not really familiar with the internals of engines (as far as putting one together, I know what everything does, just no hands-on internal work).
Is there a way to adjust these valves? Do I need to pull them and make sure they aren't bent (none of the others are?!?)?
I'll see if I can get some pics.
P.S.-I didn't realize that the car had a MLS...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 06-04-2007, 10:00 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Valves, not seating?
First things first, there is only one head. Second, if the cams are installed, you will never have all of the valves closed at the same time. With the cams removed you can check the closing of each valve. But, if compression is good, the valves are closing fully. Even the slightest gap at the seat will result in zero reading during a compression test.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-04-2007, 11:31 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Kevin is right about if there are cams in you will always have valves open and closed, but I'm assuming you pulled the cams before you took the head off, it seems much easier to get the head bolts out that way. Anyways, there's no way to adjust the valves on theses cars, they're hydraulic lifters so you'll need to be pulling those valves. I'll put $1 down that you'll be joining the "bending valves 101" club with Dustin and I.
95 Talon TSI AWD
97 Eclipse GST
Old 06-05-2007, 07:33 AM
Mikelb's Avatar
Ok, I have pulled the HEAD... sry for my mistake, I realize there is only one... I'm used to a V6.
I didn't pull the cams, but I can rotate them slightly and get the valves to close on cylinders 1 and 4, they didn't close on 2 and 3. I'll pull the cams, but isn't there some specific pattern for removing the bolts (I don't have $$$ or a manual right now).
It wasn't hard to remove the headbolts with the cams in place. That's what an extension and breaker bar (with added pipe ) are for. 20min tops. (yes, I used the correct torque procedure, in reverse).
Old 06-05-2007, 07:56 AM
smoke121212's Avatar
smoke121212 smoke121212 is offline
wow you can tell he gambles a lot.
1996 eclipse gs
cold air intake, thats right im super fast now! wooooooooooooooooooooooooooooooo lol
If a man says something in the woods and there are no women around to hear him, is he still wrong?
Old 06-05-2007, 05:41 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I learn more in one of Kevin's posts than I do in any 20 others I read.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-05-2007, 07:46 PM
AF - Advisor
Thanks, but my POS is still slow, so take anything I say with a grain of salt.
There is no real specific order for take off the cam caps, but the typical outside in pattern wouldn't hurt. I do the opposite putting the caps back on. Keep in mind that the cap bolts only get about 18 ft-lbs since they go into aluminum.
If you only rotated the cams slightly as your post implies, all valves wouldn't close, you would have to do at least one complete rotation to get them all. If you rotated the cams and the valves didn't close when the followers were on the base circles that is not a good sign, but I would pull the cams to be sure. It's possible to have other problems, like pumped up lifters, etc.
For reference, with the head setup at TDC for #1, #1 would be in overlap and number 4 is in compression, so they should all be close to being closed and only a few degrees of movement would be required to close them all. Cylinders 2 and 3 would be in either intake/compression (BDC, intake valve will remain open until ~30 degrees ABDC) or power/exhaust (exhaust valve opens before BDC in the power stroke), so valves would be open on both of those cylinders.
Kevin Jewer
Old 06-06-2007, 08:02 AM
Mikelb's Avatar
You know that actually makes sense when I think about it... cylinders 1 and 4 (with the heads removed, cyl 1 at TDC) are closed, 2 and 3 are not. I didn't rotate the cams but a few degrees, b/c I didn't want to damage the journals(?). Cyl 2 and 3 have the int valves open, so it all makes sense. I'll remove the cams just to check the valves, but they're probably ok (I would assume, the car ran fine before it sat). I might check the lifters too.
Thanks
