Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-04-2007, 11:25 AM
docfidel docfidel is offline
JGC 96 laredo wont start
My JGC 6 cyl. was running fine for months after I bought it, suddenly while in red light simply stopped, started after aprox. 10 min, and stopped again at red light, got it back home. After that, every day I turn it on, runs at my garage for aprox. those 10 min and stops, not been able to restart for aprox a hour, took it to several dealershop, said it was the battery so I changed it, did not solve the problem, the manual codes came out 12 and 11; any help would be very apreciated.
Old 06-04-2007, 01:08 PM
legalfee legalfee is offline
Re: JGC 96 laredo wont start
Probably your crankshaft position sensor or related wiring. SJ
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 06-04-2007, 04:32 PM
Thanks, Ill try checking it and replacing it, all right later here to say how it went.
Old 06-22-2007, 01:55 PM
I still have the same problem with my cuadratrac Jeep GC 1996, it still stops and wont start again after a few minutes. I changed the battery, replaced with new ones the crank and camshaft position sensors, changed sparkplugs and cables, but still is not running, any other posibilities!???? Help will be apreciated!!!
Old 06-22-2007, 09:22 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Are you still getting an 11?
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 06-23-2007, 05:33 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Sounds like either the Ignition Coil or Fuel Pump is overheating. When this happens again - Remove the gas cap, hold you ear close tot he filler hole and have someone turn the key to the ON position (without starting) and listen for the fuel pump to kick on (whirring sound).
If you can here the pump kick on the it is probably the Ignition Coil that is bad, when replacing the ignition coil I recommend replacing the plugs, wires, cap and rotor at the same time.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 06-24-2007, 08:13 AM
I am going to check the ignition coil today, and if bad will replace it also, I allready checked the fuel pump with a gauge, running fine, will write later if I get good news!!
