Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-04-2007, 07:31 AM
Carney Carney is offline
'89 transfer case got noisey
I put manual hubs on, taking off automatics. After about 100 miles the transfer case sounds as if the gears are trying to strip.
will not shift into a gear in 2 wheel drive, as the gears only clash and will not engage. In 4 wheel drive it will shift into gear with a clunk then it will move at low speed without clunking. Reverse seems to be fine.
Thanks
Carney Pace
Old 06-04-2007, 10:36 AM
2000CAYukon 2000CAYukon is offline
Re: '89 transfer case got noisey
Thanks
Carney Pace
First thing to do is to see if the snap ring on the output shaft broke. You can do this by removing the tail shaft housing. See http://www.drivetrain.com/gillies/Tcasesaver.html for details.
//2000CAYukon
