Old 06-03-2007, 09:10 PM
PlayStation3 PlayStation3 is offline
static
hi i have a friend that says when he breaks his subs will play static like sounds. now the first thing that came to mind with me is ground. but i was wondering what all of you knowledge able people could help.
Old 06-03-2007, 10:18 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: static
Probably picking up interference from either an ABS system, or the brake lights. But the ground is a good place to start.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 06-07-2007, 10:09 PM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
Re: static
could be induction
SELLING THE HONDA...
Old 06-08-2007, 06:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: static
the RCA's to the subs are picking up "pops" from the lights to the brakes. Try moving te RCA's.
Old 06-09-2007, 03:21 AM
Re: static
i found the problem the rca was lose he told me he checked it but when i went and looked it was almost about to fall off.
Old 06-09-2007, 03:33 PM
NAVY IC's Avatar
Re: static
it's cool you found the problem, it threw me off 'cause you said it only happened when the brakes was applied.
maybe it was moving around with the car movements since it was barely connected...
Old 06-09-2007, 10:20 PM
Audio Guy
Re: static
there wasn't a ground on the one that was loose, so everytime the brake lights when on it induced a pop
Old 06-09-2007, 10:23 PM
NAVY IC's Avatar
Re: static
oh ok i get it
Old 06-09-2007, 11:21 PM
Re: static
heres something: 2 weeks ago i put up my backseat because i went to a busy mall that has a theft problem and i have my amp's on the back of my seats and during the putting it up it pulled 1 rca off just enough to make that channel have really bad alternator whine so i am wondering how could that make it have alternator whine when that rca was not even close to any power/ground wires.
Old 06-09-2007, 11:29 PM
NAVY IC's Avatar
Re: static
the signal voltage going thru rca cables are so small, (mV) its very easy to pick up
noise, as a matter of fact, it can induce thru ground easier than it can thru a
grounding cable...
Old 06-10-2007, 08:27 AM
Audio Guy
Re: static
yep, this was one of the reasons they went to 4-8V outputs on the headunit - it has more immunity to noise. As for the half unplugged RCA, the signal ground was gone so it was a LOT more suceptible to noise.
