Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 06-03-2007, 08:12 PM
trainerjim23 trainerjim23 is offline
Drivers Side Door Chimes with no key in ignition and with headlights off & door open
When the drivers door is open on my 2001 ford focus the door chime rings when there are no keys in the ignition and with the headlights off. It will turn off when the car is started but will ring when opening the door just as if you have the keys in the ignition or inadvertly leave your headlights on. Does anyone have any ideas what may be causing this and how it can be corrected?
Thanks
Jim
Old 06-04-2007, 07:11 AM
Xecutionr Xecutionr is offline
Re: Drivers Side Door Chimes with no key in ignition and with headlights off & door open
just a thought, check your trunk lock, and see if something got bump in it to cause the chime to go off.
Old 06-04-2007, 07:20 AM
When the trunk is not lached a door open light stays on on the dash so I don't think it's that.
Old 06-05-2007, 07:14 AM
hmmm... well i do hate that ringing noise anyway, put your key in let it chime find it under the glove box and RIP ER OUT!!!! lol thats what im planning on doing anyway lmao
Old 06-06-2007, 06:52 PM
mr_tw's Avatar
mr_tw mr_tw is offline
is the key, and headlight chime different? if you can figure out which one it is you should be able to track it down
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 06-09-2007, 07:39 PM
GringoPete's Avatar
GringoPete GringoPete is offline
Lightbulb Re: Drivers Side Door Chimes with no key in ignition and with headlights off & door o
I too have a '01 focus and had the same problem. The ignition where you actually put the key in is a round metal button in which you push into the column when you turn the key. This button sometimes sticks after you remove the key. Just push this metal button with the tip of your finger and it should pop right back out when you let go. I've been doing it for years .
