Old 06-03-2007, 08:58 PM
BikerPaintballdude BikerPaintballdude is offline
Can someone that knows alot about bass help
O.K. here it is I dont have a car yet but i will be getting one very soon and im almost positive im getting a 2002 Avalanch. Im planning on getting a box that replaces the mid gate in the avalanch. Here is what it looks like and it shows where it will be placed it is also an enclosed box http://caraudiofactory.com/20012007-...oly-p-248.html and im going to put 3 12" Diamond Audio CM3's in it. I've been reading up on the CM3's and what ive read so far is pretty good but i wanted someones opinion on it that know what they are talking about. I havent officialy decided what AMP I want because I dont know what the best amp would be to get the job done. I was told I need a AMP that has 1000-1500 RMS at one OHM. The subs have a peak power of 1000 and RMS of 500. I would prefer a Reliable 1500 RMS AMP(and by reliable I mean I want a AMP that wont shut off every minute and wont toast the subs)
So my question is what is the best AMP for the job??
THANKS
Old 06-06-2007, 03:22 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
Re: Can someone that knows alot about bass help
first off, you don't have to get your 1000-1500@1ohm, as a matter of fact, I would prefer to have my 1000-1500@4ohms or higher
THANKS
so you wanna run (3) 500w rms dvc subs off of (1) amp, what's your budget like...??
SELLING THE HONDA...
Old 06-06-2007, 09:55 AM
PlayStation3 PlayStation3 is offline
have fun paying for 1.5k watt amp at 4 ohm
Old 06-06-2007, 11:56 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Autotek mm4000.1d will do it.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 06-07-2007, 03:16 PM
NAVY IC's Avatar
you can check out ye 'ole reliable
http://www.maxxsonics.com/hifonics/amps_XXV.html
or you can fiddle with your budget
http://www.cardomain.com/shop/list.p...rder=pricedesc
i dont know if it's jus me but these guys can almost always fit the bill
http://mobile.jlaudio.com/products_a...php?page_id=29
Old 06-08-2007, 12:12 AM
if you are looking for 1k watts then yea the slash series does well.
Old 06-08-2007, 10:06 PM
wow u guys realy are as helpfull as they said THANKS, ok I looked around and I think I like this one http://www.maxxsonics.com/hifonics/amps_XXV.html But Im not sure, soo does anyone have a personal favorite that would have a balance between Power and Efficiency?? and would work for me. Thnx for everything guys!
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
first thing is, how much do you want to spend ?
Old 06-08-2007, 11:53 PM
NAVY IC's Avatar
those subs are dual 2 ohm subs
your load is going to be either 12 ohms or 1.333 ohms if you're only using one amp
if that's the case (one amp for all 3 subs), this is the one out of all the Hifonics that's the closest match:
BXi 1606D
http://shopper.cnet.com/car-amplifie...-31961789.html
it's also here, but they didn't have a price on this page
http://www.maxxsonics.com/hifonics/amps_brutus.html
Old 06-09-2007, 11:34 AM
WOW! I've been looking for an AMP that would work for probably 2 and a 1\2 weeks and found nothing, ya'll are great:]. O.K. so if this AMP realy will work and get the job done is it going to use up my battery like crazy? and if so what can i do about that?. And I've read about guys having problems with there speakers shuting off every 3 minutes because its either working the AMP or the speakers too hard am i going to have a problem with this or is the power spread out through the speakers pretty evenly and around the RMS level?(sorry bout asking tons of questions at a time but im pumped :] cuz ive wanted this for so long and soo bad and im finaly making progress)but all i want is a AMP that will power the speakers, make them blast me apart but not tear the speakers apart, and not toast the AMP. I know its not that easy but i think that the brutus AMP you showed me will work but I need to know for-sure. Well thanks for everything(expecialy to NAVY IC) because ya'll are preventing me from making a mistake that I will regret(as in getting expensive crud that dosent work). THANKS!:]
Old 06-09-2007, 11:40 AM
(Forgot to add this) umm probably in the 300 dollar range. I can be flexable with that budget because the first setup i wanted was a lot more so total (box+speakers+AMP=around 1000.
Old 06-09-2007, 07:56 PM
NAVY IC's Avatar
with the dual 2ohm version of the CM3's that amp is what you want, you're not going to have any problems with the - [BXi 1606D]...
but, if you buy the dual 4ohm version of the CM3's, then you would probably want to go with the next amplifier model up which is the - [BXi 2006D]...
it cost a lil more, but not much, (about $60), check it out...
http://shopper.cnet.com/car-amplifie...-31962093.html
Old 06-09-2007, 08:55 PM
Oh O.K. soo am I still going to wire them parallel? and whats ur oppinion about the setup im doing (three 12" CM3's) i havent realy been around very many audio setups so i dont realy know what kinda power im looking at so what im asking is - is this going to be a wind shield cracking, make my ears bleed, and get the cops called on me cuz its so loud. or am i overating it? or will i be a proud owner of a beast? >:]
Old 06-09-2007, 09:40 PM
NAVY IC's Avatar
you're actually going to have a series-parallel configuration...
what you have to do is individually wire the coils on each of your subs in series,
and then connect each of the subs together in parallel, these diagrams should help...
dual 2ohm options
http://www.rockfordfosgate.com/rftec...3&woofer_imp=3
dual 4ohm options
http://www.rockfordfosgate.com/rftec...3&woofer_imp=4
Old 06-09-2007, 10:55 PM
ok that helps alot because i know a guy that can do it but he just needed to know what to do Thanx ill probably come up with some more questions in a few days but i think im good for now thanx for everything:]
