Old 06-03-2007, 07:27 PM
mitsu3kgt mitsu3kgt is offline
Leak??
I just installed my transmission and engine in my car, but when I fill my tranny with about 1.5 quarts of oil, it starts to leak. I found where it was leaking from, now Im looking for the seal. What is the name of the shaft that goes into the transfer case from the trans?? On 3sx I see a output shaft seal and transfer case input shaft seal, which one will it be?? It is leaking form the trans, because I didnt put any fluid in the transfer case.
Old 06-03-2007, 08:12 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Leak??
Probly the OS seal. You'll be lucky iof 3sx even has it in stock. Its a part thats on BO alot.
Old 06-03-2007, 10:13 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Leak??
definitely OS seal.
don't buy it from 3SX, get it from the dealership. cost about $25.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
