Go Back   Automotive Forums Car Chat > Cars in General
Old 06-03-2007, 05:45 PM
The Hitman 2007 The Hitman 2007 is offline
What exactly affects gas milage?
I've hear alot about gas milage, and its always said that the larger engine and heavier car is the one that gets less mpg, but can this be accpeted as a fact? I see v6 blazers that get 15mpg and under with a weight around 4000-4500lbs, then see v8 dodge durangos around 5000lbs that can easily get 18-20mpg. So I come to the question, what exactly are the true factors on MPG?
Old 06-09-2007, 07:50 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: What exactly affects gas milage?
there are MANY MANY things that'll make you burn more or less fuel. basicaly, anything that moves you from A to B less efficiently will make you burn more fuel. just to name a few: aerodynamics will affect economy (especially at high speeds), weight will affect economy under acceleration, anything that makes your engine less efficient will burn more gas, a larger engine (given the same efficiency) will burn more fuel than a smaller engine, friction and weight in the drivetrain will lower economy, etc. etc. etc...
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 06-11-2007, 05:47 AM
ShadowWulf2K ShadowWulf2K is offline
Also, things like the age of an engine will affect fuel economy. If you have two engines of identical displacement and horsepower, but one is new and the other was designed 20 years ago, the newer engine will have better mileage because of improved modern technology.
