Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-03-2007, 05:04 PM
edstelmach edstelmach is offline
Ring gear access plate
I'm putting a new water pump on my 1991 Cefiro (RB20DET) engine.Not enough room to get the harmonic balancer bolt off even with radiator off,will need to take more parts off.Need info on the following option.
Where is the access plate (and description..size,etc.) so I can lock the ring gear to keep the engine from turning over?Also is there any oil to collect on removing the inspection plate?
Help and advice greatly appreciated.
Old 06-04-2007, 01:35 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Ring gear access plate
Generally: between engine block /tranny, accessed from below. Oil doesnt come out from here, although leaking crank oil seal might keep area messy...
Make ' 4" more space': Jack engine up one inch, then loosen engine supports, lower engine down.
