Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-03-2007, 03:54 PM
Macalantern Macalantern is offline
Unhappy Lighting troubles.
I have a 1993 civic ex, its a hatchback. Last night I was informed I had no running lights what so ever. we checked all the fuses and all the wires and bulbs and everything like that and still my tail lights license plate lights and front corners dont work. Can anyone tell me what the problem could be? All the break lights and turn signals and headlights work. also I was wonering are the license plate tail lights and dashlights all connected some how? if you could answer asap it would be greatly apprecieated.
Mac
Old 06-03-2007, 09:41 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: Lighting troubles.
check the wires with a multimeter. and then check your relays.
-tony-
2000 honda s2000
Old 06-04-2007, 09:40 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
dash isnt connected to tails.. i see this a lot... its usually an overlooked fuse... so i would double, triple check them... then i would check the relays.. if those are fine... you get to follow your wiring harness to look for broken, cut, frayed wires.. fun
