Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-03-2007, 02:59 PM
Soilent Green Soilent Green is offline
Exclamation Listen to my engine
http://www.youtube.com/watch?v=RSZ8OK1sIS0
Here is a video of my engine, you can hear a raspy rattling/grinding when I rev it up to 1000-1500 RPM, ever heard that before? More details on youtube, but don't reply there, reply here. The sound might not be so loud, you might want to turn up your volume a bit.
Thanks
Old 06-03-2007, 09:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Listen to my engine
Buy a stethoscope and see if your power steering pump or alternator is making the noise. Those will be obvious with a stethoscope. You will even be able to tell which bearing in the unit is bad.
If the sound is internal to the engine, near the fan belt area, then it is likely to be the water pump. Less likely, one of the timing belt idler pulleys.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
