Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-03-2007, 02:51 PM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
Brake rotor question
I was looking on ebay for new brake rotors for my 98 Gst and I found this company who takes Brembo blank rotors and drills and slots them is this a good idea to buy theese? Here is the link below. Also would it even make a difference if im still going to use stock pads and calipers?
http://cgi.ebay.com/ebaymotors/Eclip...spagenameZWDVW
Old 06-03-2007, 05:19 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Brake rotor question
Those look like just standard rotors that have been drilled and slotted. It's going to make a difference if you were... flying at 200mph and decided to stop quickly and for rally/autox. I've got a set like those on my car. They look good... And I'm using stock calipers and decent pads.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-03-2007, 11:52 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I've always read to stay away from drilled and slotted rotors as they tend to crack. But thats probably under race conditions. I say save up a little extra money and buy drilled rotors or slotted rotors from brembo themselves. I got the brembo slotteds.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-04-2007, 12:36 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Just get stock replacements. I wouldnt waste money on something that has the potential to crack and break. Brakes are something I wouldnt want to fuck around with.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-04-2007, 08:33 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I went with the Brembo dimpled / slotted with a set of ceramic pads. I haven't had any problems and they have been on for about 2 years. No cracking at all.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-04-2007, 01:37 PM
Ah, but there is a difference between dimpled and drilled.
Caleb
vanilla gorilla
Old 06-04-2007, 09:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
I have friends that have had some bad cracks on drilled rotors, but that's with road racing. On the street, you are probably fine, but I would inspect the rotors closely, with each oil change perhaps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-04-2007, 10:28 PM
Gsst98's Avatar
Thanks alot for all of your help appreciate it
Old 06-05-2007, 12:02 AM
Agreeded, that's the reason I went with the dimpled.
1997 Spyder GS-T
5-Speed
Old 06-05-2007, 01:31 PM
Smooth move.
Caleb
vanilla gorilla
