Old 06-03-2007, 01:50 PM
pdbum pdbum is offline
98 s10 slipping or missing when hot
I have a 1998 s10 4.3L extended cab. 165.000 miles. after driving for 10 -15 minutes and the engine is hot, from a stop I have what feels like a transmission slip or miss when taking off. after 2-3 it disappears and all is normal. Only from a dead stop does this occur. Hiway driving OK and engines idles fine. Help me!! don't have alot of money
Old 06-03-2007, 06:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 s10 slipping or missing when hot
You need to separate the engine miss from a transmission slip.
Any check engine lights?
How is the tune up.
How is the transmission fluid level and fluid?
A engine has to be running good for the transmission to work right.
MT
Old 06-04-2007, 12:35 AM
serviced transmission 10 days ago. fluid levels OK. been a good while since tuneup. engine seems to operate well except for feww seconds on initial acceleration. also in seems to be intermitent. some times will take off fine.
Old 06-04-2007, 08:22 AM
MT-2500's Avatar
AF - Advisor
Check engine running and tune up end.
What kind of transmission service? what kind of fluid was used?
A good scanner will show up any engine running and or transmission problems.
MT
