94 mazda mx6 NEED HELP
Ok i have a 94 mazda mx6 it has the 2.0 DOHC 16 valv 5 speed manual trans. Ok when i start it. it wont keep an idle it wants to die right back out. i can keep it running with the peddle but as soon as i let off the peddle it stalls. it has a few times kept an idle but it was a 700rpm (witch is around where it should be) but it was rough idle teh car shakes like crazy. dose any one have any idea what it is???? email me if u do [email protected]
Re: 94 mazda mx6 NEED HELP
i know with my 94 mx6 i had to adjust the idle screw
with the car running just slowly adjust it giving abit of time between adjustments for the car to even out |
First is your check engine light on? If so go and do a search on the forum here to learn how to get your trouble code. Mine was on and it had these same exact symptoms, the problem I had was the Mass airflow sensor and an O2 sensor. I replaced both and have had great results, I was only getting around 210 miles per tank before, and now Im getting around 285+.
Aftre fixing these problems It did start to die at idle after a few days, but I checked under the hood and my air intake hose came off slightly, I put it back on tightley and it corrected the problem. Maybe these will help you out, good luck. |
