Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-02-2007, 03:49 PM
Edintexas Edintexas is offline
Angry 97 Rodeo A/C Clutch Removal
I have a 97 Rodeo with a noisy A/C clutch bearing. I have the new bearing but I can't get the clutch off of the compressor.
I've removed the 10mm bolt from the hub but I can't get the clutch to slide off of the compressor shaft. I've tried prying as well as using jack bolts in the three threaded holes in the face of the friction plate to no avail. There is no room for a puller unless I remove the radiator or discharge the system and remove the compressor. I'd really rather fix it in place if it's possible.
Any help would be greatly appreciated.
