Old 06-02-2007, 01:49 PM
sLADe781 sLADe781 is offline
Radiator Problem Maybe!?!
So my friend has an Integra and she says that it overheats sometime. It doesn't do it all the time but if she's stuck in traffic too long then her car starts smoking and she usually has to pull over and add water/coolant. So I was wondering if you guys had any ideas on what it could be!?! I'm kinda thinking maybe it's the radiator acting up or possibly the thermostat since it doesn't overheat all the time....thoughts?
I know she doesn't have a GT but I figured this may be a common problem so maybe someone here could help since I know you guys better than the people on the other forums.
Thanks in advance.
Old 06-02-2007, 01:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Radiator Problem Maybe!?!
sounds like the fans arent kicking on or the rad is plugged.
Old 06-03-2007, 01:31 AM
X2Xtreme360 X2Xtreme360 is offline
If she has to add coolant to the radiator, then there's probably a leak somewhere. You shouldn't have to add coolant, the level should stay at the top. There could be a leak in the radiator so when the coolant gets warm and the thermostat sends it through the radiator, shes actually losing coolant because of a leak.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 06-03-2007, 11:11 AM
Stealthee's Avatar
You will lose coolant if you overheat. It forces the water to the overflow jug and will dump it on the ground.
