Old 06-02-2007, 10:04 AM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
headlight issues???
ok my 98 gt headlights are starting to develop what i think is a common problem with all 3000gts? well for one..they both leak water..always have since ive owned it..but now one of the them is starting to turn a yellowish color..i beleive its happening underneath the plastic..is there anyway to fix this problem before it escalades out of control? ive read about takin the headlights apart..but i thought you could only do that with the 94 glass headlights? correct me if im wrong?
Old 06-02-2007, 10:25 AM
AutostradaVR4 AutostradaVR4 is offline
Re: headlight issues???
you should be able to take them apart same as the 94s, only difference is that the paint on the 94s is on a seperate piece, where on the 95-98s its right on the lexan.
anyways, id say take them apart and clean the lexan, then reseal them good so they dont leak.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 06-02-2007, 10:50 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
The yellowing is most likely the clearcoat peeling.
http://jagvr4.8m.com/hrestore.htm
Old 06-02-2007, 11:21 AM
yes ive seen that thread before actually about the wet sanding the headlights..so your saying the yellow color is on the outside of the headlight? its not a peeling effect.i cant feel the yellow spot..i think its underneath the the lexan..but im not sure..i dont wanna just start sanding down the headlights..could be an expensive mistake..
