Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 06-02-2007, 09:36 AM
vpracer vpracer is offline
Missfire on cyl 5 on a 3.5
Hi
i have 94 concorde all plugs look good except for cyl 5 it was soaked in gas would this be a coil pack problem cause its not sparking wire looked fine
Thanks Rob
Old 06-02-2007, 09:41 AM
Scrapper Scrapper is offline
AF Premium User
Re: Missfire on cyl 5 on a 3.5
sure could be in the coil pack...or a valve problem on that cylender.....good luck...
Old 06-02-2007, 09:56 AM
Thanks for the quick repley ima get new coil pack try that
if it was a valve wouldnt it still fire in that cyl
Old 06-02-2007, 10:14 AM
AF Premium User
i should have told you to do a compreson test on it first.....good luck...
Old 06-02-2007, 11:00 AM
after you said that i did a compression test and it was at 120
i did a key test to get codes there was on 38 and then it did 55 so im assuming 55 is end of codes
Old 06-03-2007, 10:00 AM
Well coil pack seem to fix the miss and dead plug but now im getting
code 12 from what i read here that means battery been disconected
code 41 anyone know what that is
and code 55 end of codes
i went to 5 diff places yesterday looking for a repair manual for this thing i ended up putting one on order
so if u happen to know what code 41 is ull be a big help
Old 06-03-2007, 10:09 AM
Talking Re: Missfire on cyl 5 on a 3.5
i found code helps when u go threw all the posts here this site been nothing but the best and i like to thank Scrapper for replying so quick ur a asset to this site keep up the great work
heres all the codes
www.allpar.com/fix/80s-codes.html
Old 06-10-2007, 05:42 PM
wafrederick wafrederick is offline
Banned
Could be blown out intake gaskets and that will cause a miss on the 1993-1997 3.5.It is a common problem and most auto parts stores stock the gaskets.Spray brake clean or carb cleaner near the gasket area when running.If there is a change,there is your problem.The worst part of the job is if one of the intake bolts break off,a lot of drilling and using an easy out.
Old 06-10-2007, 09:18 PM
Oldengineer Oldengineer is offline
I had a 95 LHS with the 3.5. It developed a misfire on one cylinder. Turned out that the long spark plug boot had developed a pinhole and the inition system was firing off thru the side of the boot to the tube that the sparkplug sits in. Suggest you pull out the sparkplug boot and give it a close inspection. If you see a a little black spot on it where its been firing off to the tube, replace the plug wires.
Regards:
Oldengineer
