Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 06-02-2007, 10:26 AM
ttutherow ttutherow is offline
1989 Lebaron crank sometimes and sometimes not
I bought an '89 lebaron 2.5 Turbo. The man had changed valve cover gasket and had unhooked the vacuum lines and it would surge the turbo. I hooked the lines up and now sometimes it cranks and sometimes not. i changed the computer and the timing delay relay and stilldoes the same. anyone got any ideas i'm at a lose.
Old 06-02-2007, 10:52 AM
Scrapper Scrapper is offline
AF Premium User
Re: 1989 Lebaron crank sometimes and sometimes not
it could be a dead spot in starter i'd take it and have it tested if i'm reading you right...like it wont turn over sometimes is what your saying?? and be sure cables are good and clean......good luck.
Old 06-02-2007, 07:17 PM
it will turn overjust won't crank. we also found out today that it stalls when driving it
Old 06-03-2007, 01:58 PM
AF Premium User
do you know if it has spark and gas because now sounds like fuel problem...no spark not getting enough gas so no run....good luck.....
