Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-02-2007, 08:54 AM
baby141 baby141 is offline
Unhappy Pulsating brake pedal and ABS light
I have a 1991 Honda Prelude. The ABS light was on so I went and changed the rotor and brake pads on both the front and back brakes. The ABS light is still on and I'm also getting some pulsating/vibrating from the brake pedal.
What can this be?
thanks
Old 06-02-2007, 11:13 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Pulsating brake pedal and ABS light
If the ABS light is on there is a problem with the ABS system, you should take it to a dealer or shop and get it inspected. While the light is on the system will not engage so you do not have the benefits of ABS until you get it fixed.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-12-2007, 10:14 PM
O'Dailigh's Avatar
O'Dailigh O'Dailigh is offline
It sounds like the slave pump for the break system may be going out. Also, did you check the lines for a leak?
~Laudir Agus Mir~
Present:
98 2.3 CL 128 mph
Past:
96 Prelude Si 142 mph
Future:
2010 Genesis???
