Old 06-01-2007, 08:18 PM
barker23 barker23 is offline
Send a message via Yahoo to barker23
94 Tranny Slipping after Engine swap
I just swapped out engines in a 94 C1500 2WD. The tranny ran great before the engine went bad. I pulled the bad engine then the truck sat for about 8 months before I finally got around to installing the new one. Now the tranny seems to want to slip when giving it gas. Ive checked and recheck the fluid and Ive gotten it up to the full mark, it got a little better each time I added more fluid but id still not 100 percent. Have I over looked something?? Thanks for any help.
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 06-02-2007, 09:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 Tranny Slipping after Engine swap
Has the transmission ever been serviced?
Filter and fluid change?
MT
MT
Old 06-02-2007, 02:08 PM
Never been serviced that I know of, only a weekend driven truck and always ran great before engine swap. I suppose servicing it should be the first thing I attemp, it just always ran so good that I was curious if anyone else has ever had a similar problem.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 06-03-2007, 10:07 PM
scoobytuff scoobytuff is offline
If your adding fluid this is probably not the problem. Did you check the tv cable adjustment (kickdown cable). I know that will make a transmission slip a lot if its not adjusted right.
Old 06-04-2007, 08:23 AM
Serviced tranny and runs great once again.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 06-04-2007, 07:30 PM
MT-2500's Avatar
AF - Advisor
Sounds good. Glad all is well. And thanks for posting back how it went..
MT
MT
