| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
We have a 91 Firebird with the 305 v8. We have a bad oil pressure switch. We bought a new one at AutoZone, located the switch but can't get to it replace it. The website and several threads in the forum mention a special socket however the folks at our local store don't know what we're talking about. It is jammed in there so we can't seem to get to it with a wrench and conventional deep sockets aren't deep enough. Any additional descriptions or part numbers would be helpful. We can go to another place I just was hoping not to turn this into an ordeal.
Thanks
1978 Trans Am Black T-tops 400 1999 Grand Am 1991 Firebird |
Re: Special socket for oil pressure switch?
is it one with a hex so you unscrew it like a nut or bolt?
you may need a crow-foot wrench or obstruction wrench. http://www.1aauto.com/1A/OilPressure...SU00003/482441 is that the part you have?
Seatbelts Saved My Life
I had to buy a special socket to replace my oil pressure switch. Its a HUGE f-ing socket. Really deep...anyways, its called an 'oil pressure switch' socket. Its like a 1 1/4 inch socket. Damn special tools.
longer with the hex near the bottom, needs a wicked long socket but I don't know how it is supposed to fit in that tight spot. Anyway help identifying what wrench I need is most appreciated
i guess you'll need the special socket like poor has.
never seen one like that. oil pressure sensors i've seen are like 1/2" hexs and stick out maybe 3/4" with a wire coming out. you just get a wrench round them and they're off in no time.
i couldn't get the one out of my 305 either, so I just bought a switch for an lt1 and put it behind the intake manifold, the wire harness was able to reach up to the new position.
I thought about cutting the top off with a hacksaw, then I can get a regular socket over the hex head. The only downside I see is that if it turns out to be stubborn I don't think the car will be driveable until we can get it taken out. It will be open. Should I try it? Am I right on that?
you could try a hacksaw or cut off wheel. there's no telling where the oil-filled section begins though. But if you are able to get a socket around it, I dont really see you not being able to get it off. they normally come off relatively easily/as expected. so I dont think you have to worry about it being stuborrn and getting stuck in a corner.
The only other option is to place the new sensor behind the intake (assuming yours is by the oil filter). You'll have to use an extension and 45 degree adapter to make it work.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Just go to autozone and get the oil pressure switch socket and be done with it. |
that's what he was saying about it not being driveable. he's not dumb enough to run the engine with a hole in the oiling system....
![]() Quote:
mmm, kay, so we cut up the old unit to get it out, how do we get the new one in?
I've got the same psi switch on my car... diff. is that it's sticking out of the front of the engine with nothing by it except the oil filter. I take it on/off by hand or vice grips or channel locks or whatever I feel like.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
