Go Back   Automotive Forums Car Chat > Buick > Regal
Old 06-01-2007, 02:15 PM
alsalehag alsalehag is offline
Post 1995 Buick Regal
Recently my car won't start while the transmission in the "Park" postion. However, it starts ok when you put it in neutral. I was told by a mechanic that this issue was due to "Neutral Safety Switch". Anyone knows how to install and where the new switch goes?? Please advise.
Old 06-01-2007, 03:51 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Buick Regal
Top of the trans where the linkage goes into the case.
Old 06-01-2007, 06:12 PM
Thumbs up Re: 1995 Buick Regal
Actually, I found the switch under the gear shifter not where you recommended. Had to wiggle the wire and sprayed WD-40. It works fine now but not sure if this really is going to be a permanent fix. Th ank you
Old 06-01-2007, 07:19 PM
A990 racer
I guess theis is a floor shifter not a column shifter, correct?
