Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 06-01-2007, 02:20 PM
TwistedVegas TwistedVegas is offline
Make it Stop! Honda 1997 CR-V odd noise
1997 CRV makes a knocking, tapping, wobbling noise on the left front side. The noise is louder at low to medium speeds, but then goes away. Both front axels, all 4 struts, brakes, and tire balancing has been done. What else should I look at?
Old 06-01-2007, 04:15 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Make it Stop! Honda 1997 CR-V odd noise
Wheels bearing or a bad balljoint.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-01-2007, 04:25 PM
Thank you!
Wouldn't the wheel beering be seen when replacing the axcel and isn't the balljoint apart of the axel...when replaced.
My thoughts so far...replace the wheel berring or get another axel?
You agree
Old 06-01-2007, 04:43 PM
NA is Best!
Jack the front end of your car up and see if you can move the wheel in any direction. In/out, front/back, side/side, up/down. Any play in a wheel is bad.
