Old 06-01-2007, 09:14 AM
GAT GAT is offline
2001 Silverado 2500hd
My brakes are very soft and with constant pressure with truck running will actually go to the floor. While out on the road the truck does stop "ok" but not great. I replaced the front pads and turned the rotors due to a large amount of rust build up on the back side of each front rotor. Installed 100.00 ceramic pads but still don't undrerstand why they are so soft.
ANY HELP WOULD BE GREAT.
GAT
Old 06-01-2007, 11:46 AM
rjeffery rjeffery is offline
Re: 2001 Silverado 2500hd
Maybe you have air in your brake lines. Try bleeding the system. You also may have a bad brake booster.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 06-01-2007, 01:18 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
That sounds more like a master cylinder than a booster; if the booster were bad, they'd just be hard to press.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
