Old 06-01-2007, 08:20 AM
BNelson BNelson is offline
Rear turnsignals not working
1993 Buick LaSabre. Turn signals, both sides, not working!! Front lights light up but do not blink, back lights do not light up. Hazards work fine. I switched the bulbs around on one side but still no luck. Any ideas????
Old 06-01-2007, 05:55 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Rear turnsignals not working
Have you tried a new flasher?
Old 06-01-2007, 11:00 PM
No I have not. Dumb question. Where is it located?
It seems to be a works sometimes but not other times. I am not sure, but one time when I stepped on the brake the right signal stopped blinking.
Old 06-01-2007, 11:40 PM
HotZ28's Avatar
AF Moderator Elite
The turn signal flasher should be under the dash on the driver side, mounted to the kick panel.
Old 06-02-2007, 12:50 PM
I took a quick look and it must be behind it, hopefully. Unfortunately it is a quite one so I can not find it that way.
Old 06-05-2007, 09:31 PM
xs03mich xs03mich is offline
On a olds that I owned there was another flasher assembly located behind the speedometer cluster. The flashers all worked but were intermintint and slow. Changed the easy to get to one first and problem was still there. Changed the difficult one out and they worked good.
