Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-31-2007, 10:59 PM
musky48 musky48 is offline
99 passport electrical problems
I am working on a 99 passport with the 3.2L. It is missing on all passenger side cylinders. I have checked every sensor on the engine and all are good. Checked injectors and coils. I just don't know where to look next. It will start but revs up very slowly. I pulled the coils on the passenger side and all are sparking fine. I can pull the coil wires and injector wires on the same side and the engine runs the same. But on the driver side it will kill the engine. Now I just don't know what can cause this to happen. I was thinking bad crank sensor and cam sensor but both are good.Could this be the computer or possible a broken wire. Any advice on what wires to look at first or if a computer would cause this maybe.
All advice welcome.
Thanks,
Ralph
Old 06-02-2007, 09:56 AM
Re: 99 passport electrical problems
bump
Old 06-05-2007, 08:06 AM
TX-LS's Avatar
TX-LS TX-LS is offline
Did you recently do any head work? Almost sounds like your cam timing is off on that bank of cylinders. Also, check your fuel supply to those cylinders as well.
Old 06-05-2007, 11:51 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Check the wire connections under the power steering reservoir for corrosion or if one came loose. There is a seperate connector for each bank.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-05-2007, 07:58 PM
It has recently had head work done. But the problem is on the opposite side. I have no less than 190 psi on all cylinders. I have had those connections apart several times and can't figure it out. The plugs are wet on that side so I assume it is getting fuel. I pulled all three coil packs and they are getting spark. I checked the fuel pressure and it is at 40 psi. if I remember right. The only code it will give me is a multiple cylinder misfire. I am kinda leaning toward the computer but hate to spend the money and it not be it. Is it possible for the computer to only run one bank? I just don't understand the fact that the problem side seems to be getting both fuel and spark but wont hit a lick. Is it possible there is a problem with the reluctor ring on the crank and the crank sensor is reading it wrong? It just has me so puzzled I am at a loss for what to do.
Thanks,
Ralph
Old 06-05-2007, 11:44 PM
Gizmo42's Avatar
If its getting fuel and spark the only thing missing is air. I'm thinking the cams on that side arent timed right.
--Dave
Rear No-Slip Locker
Old 06-06-2007, 07:25 PM
I will check again and let you know. I thought the same as you but checked them once before. Who knows, stranger things have happened.
Old 06-07-2007, 11:16 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
just getting in on this one timing is off v/c will have to come off on both sides to line these puppies up
Old 06-10-2007, 02:35 PM
Can't befieve it myself. Timing was off on passenger side. I don't know how I messed it up but I did. I guess it just took two or three people telling me it was off before I checked again. Thanks guys.
Ralph
