Old 05-31-2007, 10:42 PM
Nexagen Nexagen is offline
What is the World's Lightest 15" Wheel?
The lightest so far that I have come across is Motegi Traklite 2.0 which weighs 10.5 Lbs.
Question is does anyone know of a wheel that is lighter than that?
Old 06-01-2007, 08:18 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: What is the World's Lightest 15" Wheel?
Volk Gram Lites weigh about the same. Rota Slipstream/Spoon wheels weigh about 11-12lbs. depending on which ones you get.
The Motegi Tracklites look like knock-off Spoon/Rota wheels.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-01-2007, 09:48 PM
alphalanos alphalanos is offline
According to wheelweights.net, Porsche 916 wheels are 7lbs.
96 EJ6. Future home of boosted B18C1.
Old 06-01-2007, 09:51 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
might be a little hard to get hold of a set of those though. i think they're centre locking nut wheels anyway.
doesn't the CCX have carbon-fibre wheels?
Seatbelts Saved My Life
Old 06-01-2007, 11:16 PM
Looks like the closest to the Porsche wheels are the Volk CE28N Wheels at 15 inches they weigh 7.72 Lbs. Imagine the rotational mass savings in acceleration and MPG!
15 x 5.5 +35, 45 4 100 ~7.72 $460.00
Old 06-01-2007, 11:24 PM
This is probably as light as it gets at 7.8 Lbs. Shown here is the 19" version but it makes it easy to imagine a 15" version.
Old 06-02-2007, 07:29 AM
Yeah but the ride quality probably sucks.
Old 06-02-2007, 06:32 PM
GreyGoose006 GreyGoose006 is offline
why?
a light wheel will give you less unsprung weight and make the suspension MORE accurate and give you a BETTER responding ride.
unless your suspension is crap to begin with, but i doubt that is the case for someone who is looking for the lightest possible 15" wheel
Old 06-02-2007, 07:47 PM
Lighter wheels are impacted more by road irregularities which sends more shock through the suspension and into the cabin. Heavy wheels dont transmit as much energy to the suspension because they dont move as much when impacted.
Old 06-03-2007, 07:17 AM
but if your suspension is at all decent, you want to transmit as much as possible to the suspension.
why else do you think there is a whole industry devoted to producing light weight wheels
Old 06-03-2007, 06:26 PM
KiwiBacon KiwiBacon is offline
That's exactly what suspension is for, absorbing shock between the wheels and the chassis.
Less unsprung weight means your wheels can react faster to each bump, allowing the suspension to do a much better job, especially over sharp or high frequency bumps.
A lot of unsprung mass (i.e. heavy wheels) brings the problem of overshoot, where the momentum of a heavy wheel going up, is enough to make it lose contact with the ground at the top of the bump.
To get around this needs higher spring and damper rates, which takes it's toll on ride quality.
