Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 05-31-2007, 08:04 PM
camaro316 camaro316 is offline
92 Sundbird won't start.
My car won't start and the first thing i noticed that the fuel pump was not running and did have no fuel at all. Checked relay and its fine. A buddy told me to check fuseable links off starter. Did that and was ok but noticed stud for the wires on starter was loose. So i tightened it and now the fuel pump runs but won't shut off only when i turn the key off. I got fuel now so i checked the spark and no spark was found. What makes the fuel pump run continuesly and won't give me spark. Buddy says it may be the ignition control module or the cole pack may be bad cause the fuel pump runs off them. Car turns over great but does not act like it wants to start at all. Help please.
Old 06-06-2007, 12:47 PM
Re: 92 Sundbird won't start.
I tested the coil pack and thats fine. The coil pack is getting power. The cps does not have juice going to it. To me i think the computer is bad. Please help.
Old 01-16-2008, 12:44 PM
mcmalloy mcmalloy is offline
Could be the crank shaft sensor ,its at the back side of the engine.The last one i replaced i had to take the oil pan off because it had build up on it and would not come out .
