Old 05-31-2007, 06:03 PM
Slam33 Slam33 is offline
A/C Question
I have a 1997 Grand Prix LE. I have a issue with my AC. It has no leaks, the compressor turns on, but no cold air. When I had the system drained I put one tank of R124, and the gauge was reading over charger. My compressor is also making a noise as well. Does the compressor need to be replaced. Any help would be great.
Thanks
Ernie
P.S. Please help It it 100+ where I live
Old 06-01-2007, 10:24 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: A/C Question
your car should require about 3 12oz cans of R134-a refrigerant and 6-8 oz of compressor oil. If it shows overcharged after only one can, there is a blockage in the system or a compressor issue. Since your compressor is making noise, I think it to be your problem (especially if you didn't add oil when adding refrigerant). If you decide to spend the money to replace the compressor, also change the accumulator/receiver drier and orifice tube/filter to avoid metal particles from the bad compressor from getting in the new one.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-01-2007, 06:36 PM
Re: A/C Question
Would it be a good idea to rebuild it? If so what is the best way to get the kit??
ERnie
Old 06-01-2007, 11:03 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: A/C Question
Rebuild what and what kit? Just go with Rich's suggestion. It could be a compressor but proper A/C diagnostics should be run to determine if it is bad by comparing the low and high port readings against typical A/C repair charts like in the FSM. Otherwise, it is just a guessing game. In addition to the compressor, if bad, the accumulator should always be replaced. Also, if the refrigerant charge is low the compressor will produce a motorboating sound.
Timeslip 08/12/06
AF Community Guidelines
