Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 05-31-2007, 05:47 PM
carl estell carl estell is offline
carl f150 airbag
Hello I have a 2001 f150 4x4 it was hit in the front and and the dr airbag deployed .I have changed the bag and sensor and iam getting 2 lights and then 9 lights on the airbag light .has any body seen this thanks
Old 05-31-2007, 08:45 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: carl f150 airbag
A LFC 29 indicates Incorrect Vehicle ID.
The restraint control module (RCM) monitors the electrical condition at C208 pins 10, 13 and 14 to determine if it is installed on the correct vehicle. Each vehicle configuration (Expedition with and without side air bags and Navigator with side air bags) will have a unique vehicle ID. If the RCM detects other than the expected programmed condition on any of these pins, it will store diagnostic trouble code (DTC) C1414 in memory and flash a lamp fault code (LFC) 29 (or higher priority code if one exists) on the air bag indicator.
Possible Causes
An incorrect vehicle identification code can be caused by:
  • internal RCM fault or an RCM installed on the wrong vehicle.
  • an incorrectly programmed RCM.
  • vehicle ID pins not connected as expected.
I am guessing you may have a bad RCM (Restraint Control Module) because these will usually need replaced after a deployment. The module will also need programmed! Dealership can do this for you.
Old 06-01-2007, 06:29 PM
thanks Johnny i did put another RCM from another truck so i need to have the dealer reprogam it
Thanks again
Carl
