2003 Impala LS. Clunking noise??
1) When I am in reverse and I have the steering wheel turned to the right, I would only hear 1 clunk (but no clunk if the steering wheel is turned to the left). Now I hear multiple clunks. 2) As I accelerate after backing up and the wheels start to straiten up I hear multiple clunks. 3) When I accelerate after a complete stop, I hear the clunk. I was hoping to find out what is causing this noise, what it takes to fix it, and how much is it going to cost to get it fixed??
Re: 2003 Impala LS. Clunking noise??
Check the boots on ur front axles and see if they're torn. Lets hope that clunking isnt coming from the trans.
![]() 97 Seville STS 95 Lumina about to get a 3.8 supercharged 97 Mustang 3.8 06 Charger RT 5.7 Check out the 1 of a kind whips http://www.cardomain.com/id/NoctrnlCreations |
Sounds like it could be the intermediate steering shaft needing lubricated. Common W-body problem. It could also be worn out tie-rod ends.
Hi,
Can you tell me what happened to your car, and what the problem turned out to be? I am having the same exact issue right now, and am currently $300 into my search for a repair. Any insight you can offer would be most appreciated. Thanks Ken [email protected] Quote:
Hi,
Under the dash on drivers side there is a boot covering the intermidiate steering shaft. Spray some grease into the universal joint both end may take a couple of time, but it stopped the noise. Dealer wanted $80 to do same thing.
Another thing it could be is the swaybar links on the rear of car, there are no grease inserts, so I had to force grease in with a needle attachment on my grease gun, found it at a Ace Hardware store.
