Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-31-2007, 03:00 PM
emcfarla emcfarla is offline
backfiring, sputtering
I have an 2001 Saleen S-281. The past few months occasionally when you start it it won't turn over. Then it will backfire and start just fine. Then a month or so ago I noticed that most of the time it runs alright but about 2 to 3 times a week, when given gas, it sputters pretty bad. It almost feels like it's running on 7 cylinders. Our mechanic said it could be a camshaft sensor and that I should probably replace the spark plugs. Being that a fouled plug may be the reason for the hestiation when giving gas to it. The only performance part I have is an off-road x-pipe that has been on the car for about 2 years now, and until recently I had no problems with the car.
Old 05-31-2007, 10:04 PM
reekor reekor is offline
Re: backfiring, sputtering
Are you getting a misfire? Did you have a diagnostic scan done?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-01-2007, 08:39 AM
I'm in the process of selling the car and a potential buyer took the car to Auto Zone, and I know they don't have the best scanning devices, but the code for the cam shaft sensor came up.
Old 06-01-2007, 11:20 AM
With that said, I would go ahead and change the cam shaft sensor.
