Old 05-30-2007, 11:23 PM
jimmyv-21's Avatar
jimmyv-21 jimmyv-21 is offline
another ABS/TRAC question
01 gp gt 3.8, 72k
the other day i pulled out kinda hard, drove for about 2 blocks, and then the power steering pump started whining real loud. so i check fluid and it is just a hair low. added some lucas ps fluid. drove it and whine seemed to to mostly go away, but now the abs and trac lights are on.
the brakes seemed a little funny too. in the past they seem to have grinded or thumped every once in a while.
from searching the forums here, i think it is a hub bearing.
thanks in advance for your help.
Old 05-31-2007, 05:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: another ABS/TRAC question
Most likely the abs/trac off lights are a hub bearing. The power steering issue is unrelated, and is most likely a pump going south. the pump's not as bad a job as it looks to change either. You can get to the lines from the bottom) by removing the passenger side front tire, and to the bolts securing the pump to the engine by taking out the radiator overflow bottle (2 nuts on top). You'll need a pulley remover/installer tool (Auto-Zone has one in their free tool loan program) for changing the pulley to the new pump. I did mine in less than an hour from start to finish. the hub is the same story. If you can do brakes you can do a hub. Just be sure you buy a quality replacement, don't use an impact wrench, and tighten everything to spec with a hand torque wrench.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-31-2007, 10:13 AM
jimmyv-21's Avatar
how do i determine which hub is bad? can i drive it with these lights on?
thanks rich
Old 06-01-2007, 11:33 AM
richtazz's Avatar
You're welcome Jimmy. Jack the car up and try moving the tire at different positions. The one with free-play is the bad one. You can also use a digital multimeter across the harness terminals of the abs sensor, it should spec at about 1k ohms.
